LabWindows/CVI
A "VISA Resource Name" control
In LabVIEW there is a"VISA Resource Name" control which lists all the VISA resources, is automatically updated when devices are plugged or un-plugged, and has a Browse functionality.
With CVI you can use NIDAQmx_NewDeviceCtrl( ) on a string control, but this lists only the DAQmx resources.
Is there another function I can use to have all the VISA resources listed?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,085 Views)
there is the function viFindRsrc which you can use to programmatically find all available resources, see here
(4,079 Views)
there is the function viFindRsrc which you can use to programmatically find all available resources.
I didn't write in my post, but I've already looked at this function.
The problem is that I have to write code to update the VISA resource list, periodically calling this function.
I prefer an automatic function.
Vix
Using LV from 7
(4,073 Views)
Accepted by vix
Hi Vix,
it seems to be the only solution. Here you can find also an example.
Hope it helps!
Bye,
Licia
(4,050 Views)
