08-27-2012 10:06 AM
Hi all,
i need to add fonts to CVI for barcode (specially 128). I copied the polices into Windows/Fonts and i suppose that CVI will detect it after that. While, he dont. What shall i do?
Best regards.
Solved! Go to Solution.
08-28-2012
11:38 AM
- last edited on
08-21-2026
05:27 PM
by
Content Cleaner
FibiIA,
There is a useful Help document for CVI that explains the different ways of using fonts in CVI.
LabWindows/CVI Help » Using Fonts
How are you attempting to use this font in your application?
08-29-2012 02:46 AM
Hi Jared,
I need to put a text which its font is a bar code 128. So, i copied into windows/fonts and i expect that CVI will load it as do word or excel. I will check the help of CVI if there is a solution.
Thank you for replying and i will appreciate if you can help me more.
Best regards.
08-30-2012 10:45 PM
You should be able to display barcode fonts by changing the Text Style for most user interface text controls. Below is a screenshot of a user interface displaying barcodes.
I did this by opening the Edit window of my Text Box Control and selecting Text Style.
Then I changed the Font to a barcode font.
Hope that helps.
08-31-2012 04:19 AM
Hi Rohama K,
The fact is that i don't find the font of bar code 128 in the list of fonts when openning the window of Text Style.
I need find the way of loading a new font to labwindows.
Best regards.
08-31-2012 07:50 AM
To get my font to show up, I installed it by following these directions. What OS and LabWindows/CVI version are you using? Are you able to see the font in Word or Excel? Can you attach the font so that I can try?
09-03-2012 03:12 AM
Hi Rohama K,
I use Windows 7 and LabWindows/CVI 2010. In word and excel i see the font.
09-03-2012 04:04 AM
here the font
Thank you
09-04-2012 02:51 PM
FibiIA,
I attempted to open your attachment (C28TGCFZ.zip) but it said the .zip file was invalid and could not extract any files. Could you please try re-attaching?
09-05-2012 03:14 AM
Hi jallen88,
Here's the font.
