LabWindows/CVI
Auto-generated header has "Redefinition of macro "
The header file generated from the uir file has a duplicate macro definition. I deleted the file and rebuilt and got the same results:
"FMTSTCAL.h"(547,45)   Redefinition of macro 'Menu1_Test_SEPARATOR'.
(3,365 Views)
It seems you have added two separators to a menu with the same name.Try renaming the separators to obtain different names (e.g. SEP1, SEP2...)
(3,358 Views)
Accepted by randyo
Thank you. I inherited the .uir file (from 1992! LabWindows v 2). I'll take a closer look at. Thanks!
(3,353 Views)
