LabWindows/CVI
Background color bug?
The customized background color of CVI often get lost.
I don't like the white background.  So I changed it to black.  But CVI often changes it back to white without my approve.
Where CVI save the background color information?  I'd like to make a backup copy.
I'm using Vista 32bit version.  CVI 8.1.1
George Zou
George Zou
(4,866 Views)
Hello George,
CVI stores its color information in the registry.  You can find the key for CVI 8.1 at HKEY_CURRENT_USER\Software\National Instruments\CVI\8.1\ColorPreferences.  I hope this helps.
Best Regards,
Software Engineer
Jett R
(4,837 Views)
Thanks.  That solved the problem.
George
George Zou
(4,828 Views)
JettR wrote:
Hello George,
It seems this trick doesn't work for CVI 8.5.   Any idea?
George Zou
(4,673 Views)
Hey George,
That is interesting behavior.  For CVI 8.5, I am assuming you are making a backup copy of the entire HKEY_CURRENT_USER\Software\National Instruments\CVI\8.5\ColorPreferences folder.  I am also believe that you may have multiple versions of CVI on this computer.  What happens if you merge the color preference folder into all of your CVI versions?  I look forward to hearing back from you.
Best Regards,
Software Engineer
Jett R
(4,634 Views)
Hello Zou,
after you change your CVI colors and restart CVI, do the new colors persist? If so, then it would seem like a Windows problem where the registry entries are not saved correctly.
Best regards
LDP
(4,609 Views)
Tried on my laptop.  Seems working.
George Zou
(4,584 Views)
