Button and If()
Good day,
do you know how to modify the if () condition when I press a button to execute it?
if(EVENT_COMMIT == CallbackProtokolSklon)
	 WordRpt_GoToCell (tableHandle,1, 3);
	 WordRpt_SetTextAttribute (g_docHandle, WR_ATTR_FONT_BOLD,WRConst_TRUE);
	 WordRpt_SetTextAttribute (g_docHandle, WR_ATTR_FONT_UNDERLINE,WRConst_UnderlineNone);
	 WordRpt_SetTextAttribute (g_docHandle, WR_ATTR_FONT_NAME, "Times New Roman");
	 WordRpt_SetTextAttribute (g_docHandle, WR_ATTR_FONT_SIZE, 9.0);
	 WordRpt_SetTextAttribute (g_docHandle, WR_ATTR_TEXT_ALIGN,WRConst_AlignLeft);
	 WordRpt_WriteToCell (tableHandle, 1, 3, "Mezní sklon [‰]: ");
I write the word about 6 buttons anyway, but I need to say one more thing after pressing one button.
It must remain in the one method, I do not want to call it via the button function.
not sure how to do this?
Thank you
Message 1 of 8
(5,498 Views)
I must admit that I don't understand your question! Can you clarify it better?
Message 2 of 8
(5,480 Views)
I am sorry for my English.
If I press the "gradient" button, I want the condition to be executed.
I don't know how to make this condition entry.
Message 3 of 8
(5,473 Views)
Sorry, I didn't focused on the code. The correct code for a control callback is:
int CVICALLBACK CallbackProtokolSklon (int panel, int control, int event,
    void *callbackData, int eventData1, int eventData2)
   if (event == EVENT_COMMIT)
       // Your code here
   return 0;
where 'event' is a parameter of the callback itself.
Message 4 of 8
(5,467 Views)
Accepted by MajklS
Thank you for answer
As I wrote, I didn't want to put it in the function of calling.
I solved it differently
 if(vypisSklonu==1)
	 WordRpt_SetTextAttribute (g_docHandle, WR_ATTR_FONT_BOLD, WRConst_TRUE);
	 switch(Jazyk){
	 case 0:
	 Fmt(buffer,"                            Mezní sklon:  %f [‰]",mezSklon);
	 break;
	 case 1:
	 Fmt(buffer,"                            nevim:  %f [‰]",mezSklon);
	 break;
	 break;
Still thank you for your help 🙂
Message 5 of 8
(5,419 Views)
Glad to know you solved your problem. Just out of curiosity, where is this code placed? In a control callback or is this a standalone routine?
Message 6 of 8
(5,415 Views)
I defined a global variable "vypisSklonu".
If you press the "Gradient" button, the value of the variable will be 1. and the condition is executed if(vypisSklonu==1)
So I can use a variable in any source code.
	switch (event)
		case EVENT_COMMIT:
		vypisSklonu=1;
			if (Jazyk == 0)
		 protokolSklon();
			if (Jazyk == 1)
		 protokolSklon();
			if (Jazyk == 2)
		 protokolSklon2();
			break;
	return 0;
Message 7 of 8
(5,412 Views)
This is not what I asked. Those lines that call WordRpt functions where are located?
Message 8 of 8
(5,400 Views)
