C TDMS DLL Visual Studio 2008
I am pretty new to C/C++ development but I downloaded the C DLL for TDMS reading/writing. First I just opened the readFile.c sample and it said it couldn't find a needed header file. Then I made a new solution in Visual Studio 2008 where I made a c file and an h file and copied in the code from the TDMS C package. During compile I get errors like:
Error    1    error LNK2019: unresolved external symbol _DDC_GetLibraryErrorDescription@4 referenced in function _main    readTDMS.obj    TDMSNI
Can someone give me a step by step instruction on how I can run the readFile.c in the Windows console and see it read the data?
(4,170 Views)
(4,163 Views)
That didn't help since I no longer have LabView installed on my computer and only have few remains in the NI folder. As far as I understand the TDMS format is open so can't I just write a TDMS reader using these DLL's without having LabView installed?
(4,137 Views)
Did you just create a header file or did you add the nilibddc.h from \dev\include directory as mentioned in the README:
The 'dev' directory contains the header file, import libraries, and binaries
to be used during development.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(4,127 Views)
