CVI Expired Message
The message goes away when I run with an external version of CVI but is still there when I run the internal version of TestStand.
Message 11 of 13
(2,165 Views)
I am also getting the same message that "Current Program has exceeded the maximum time allowed in this demo version of Labwindows/CVI" when I run Teststand Sequence files.
I did have a demo version before, but I uninstalled it now, but this message keeps coming.
I am using C/C++ adaptor and my DLL was generated from CVI.
How could I kill this message.
Thanks in Advance
mama007
Message 12 of 13
(1,982 Views)
Hi mama007,
You need to rebuild any CVI DLL you created while in eval mode, otherwise you will still see this message even if you installed the licensed version of CVI.
Best Regards,
Jonathan N.
Message 13 of 13
(1,975 Views)
