LabWindows/CVI
Can InstallWinMsgCallback receive joystick notifications?
I had tried to use the InstallWinMsgCallback to capture joystick events.
However, the routine does not seem to work. I had tested the above routine using WM_KEYUP and it works.
Any possible reasons?
I use the following code to channel the joystick messages to CVI.
main_panel = GetCVIWindowHandle();
result = joySetCapture((HWND)main_panel, JOYSTICKID1,10 FALSE);
(3,210 Views)
What is returned into result after calling joySetCapture? Also, did you call joyReleaseCapture before joySetCapture to release it from other windows?
(3,203 Views)
It returns zero - JOYERR_NOERROR. The code for InstallWinMsgCallback is InstallWinMsgCallback(panelHandle, MM_JOY1MOVE, joystick_callback, VAL_MODE_IN_QUEUE, NULL, &post_handle); Does InstallWinMsgCallback handle multimedia extension window messages? I can read all the joystick movement and buttons using joyGetPosEx but I could not get the CVI to receive the joystick message. rgds
(3,200 Views)
I believe this should work in CVI, but I don't have a joystick to test this on. I found a CVI instrument driver for joysticks that could make a good example (or you could use the instrument driver itself). In particular, the JoyWndProc function in joystick.c is handling the messages you mentioned.
(3,184 Views)
