LabWindows/CVI
Changing the Item List Color in Ring control
I tried to change the color of an item in a ring control using the following syntaxe
ReplaceListItem (MeshedTabHandle, MESHED_MATERIAL_LIST, 3, "\033fg0C0C0 SAVE", -2);  and I got the following result:
What did I wrong?
I'm using CVI2013 SP2
(3,958 Views)
Accepted by Bertrand_ENAC
As far as I can understand, colouring elements can be done in list boxes only. The only option you have for ring controls is creating a separator line. Even SetRingItemAttribute does not list colouring option.
(3,929 Views)
In fact I just wanted to change the color to simulate a dimmed item, so SetRingItemAttribute is fine.
Thank you.
(3,924 Views)
You're welcome!
(3,920 Views)
