LabWindows/CVI
Conditional switch (#if / #ifdef) for 32 versus 64 bit compilation
Is there a switch for CVI 10 that allow precompiler defines to be switched when the CVI environment changes?
I can create a user defined value and manually a user defined value but I figure that an "automatic" variable might exists.
(4,054 Views)
Accepted by blakney
Hi blakney,
The term to search for is "predefined macros". Not just for CVI: the GCC and Microsoft Visual C++ documentation use the same term. Here's the CVI 2010 version: http://zone.ni.com/reference/en-XX/help/370051T-01/cvi/usermanual/prjpredefinedmacros/
Automatic variables are something else entirely.
Brad
Brad Keryan
NI R&D
(4,052 Views)
Thanks Brad K,
Sorry I know I should have been figure this out but I had already spent too much time there.
Greg
(4,039 Views)
