LabWindows/CVI
Default value for a struct element
I would like to know if it is possible to assign a default value for a struct element?
Something like:
struct Device {
    int ID;
    double position;
    char IPAddress[10]="127.0.0.1";
    int TimeOut=25000;
Thank you for your help!
Mathieu
(5,878 Views)
Accepted by MathieuG
in C a struct is a data type, and you cannot assign a default value to it.
You can assign a default value to a variable of type struct, with the following syntax
struct Device myDevice = { 0, 0, "127.0.0.1", 25000};
Hope this helps,
Aldo
(5,876 Views)
Ok, thank you for the information!
(5,868 Views)
