LabWindows/CVI
Disable softkey F2 & F3 in table
we have an application written in LabWindows 6.0. There is an panel with a table control. On the panel also are function softkeys F1-F10. With softkey F2 or F3 i switch to another panel. There are no Problems.
Now we use LabWindows 8.5.1 with the same application. When i use the softkey F3 on the panel with the table control, it will open a popup "Find in Table Cells". But i will switch to another panel. With softkey F2 the table cell switch to edit mode, but i will also switch to another panel.
How can i disable this functions in the table control. I can't use other softkeys to switch the panel.
Greetz Be-Mo
Message 1 of 9
(4,490 Views)
Hello Greetz,
When you catch the EVENT_KEYPRESS event for those keys in either the panel or control callbacks, you need to return 1 from the callback function, instead of 0. Returning 1 ensures that the CVI user interface will not continue processing the event.
Luis
Message 2 of 9
(4,473 Views)
Hello Luis,
i know this. But the problem is, you don't become any event from this key.
When you press F3 in a table control, you don't become a event on the callback from F3. It will be open a popup "Find in Table Cells". When you press F2 in a table, then the cellsswitch to edit mode and when you press F2 again, then you become a event on the callback. But on F3 you never become an event.
I have search for an attribute or function to disable this popup in the table, but i don't found anything.
Greets Be-Mo
Message 3 of 9
(4,458 Views)
Hi Be-Mo,
while it's true that "Find in table cells" panel is displayed before the table callback receives the keypress event (so it's not possible to disable F3 facility this way), you can actually disable the edit mode switch by swallowing F2 key event by adding these lines to the table callback:
case EVENT_KEYPRESS:
      virtualKey = eventData1 & VAL_VKEY_MASK;
      modifierKey = eventData1 & VAL_MODIFIER_KEY_MASK;
      if (virtualKey == VAL_F2_VKEY) return 1;
   break;
Message 4 of 9
(4,448 Views)
Hi Be-Mo,
  i have only CVI7.1.1, so i cannot test this solution.
  But maybe you can try HideBuiltInCtrlMenuItem to disable search function.
Message 5 of 9
(4,422 Views)
Unfortunately HideBuiltInCtrlMenuItemoperates on menu items included in the context menu shown when right-clicking on the table, not on panel shown when pressing F3. The context menu can be completely disabled by calling SetCtrlAttribute with ATTR_ENABLE_POPUP_MENU attribute.
Message 6 of 9
(4,419 Views)
Hello OVR_CZ and Roberto B...
with HideBuiltInCtrlMenuItem(panel control, VAL_FIND) you can disable the popup "Find in Table Cells" when pressing F3.
Also SetCtrlAttribute with ATTR_ENABLE_POPUP_MENU disable this popup.
Thanks a lot.
Greetz Be-Mo
Message 7 of 9
(4,414 Views)
Thanks a lot.
Greetz Be-Mo
Ok, seems you never stop learning something new! Smiley Surprised
Thanks for the tip Smiley Happy
Message 8 of 9
(4,411 Views)
You could also clear the shortcut key....
SetCtrlMenuAttribute (panelHandle, PANEL_TABLE, VAL_FIND_NEXT, ATTR_SHORTCUT_KEY, 0);
Message 9 of 9
(4,387 Views)
