05-21-2019 04:30 AM
Hi all,
I am trying to create 64-bit DLL for the driver of a device so that I can use it in LabVIEW 2014 64-bit. The information for the instrument is as follows:
instrument: Rohde & Schwartz SMF100A signal generator
Driver type: VXI plug&play
I have made a DLL project in LabWindows/CVI 2019 and loaded all the .c, .h and .fp files provided by Rohde & Schwartz as the LabWindows/CVI driver. When I try to build the project in the 'Release64' mode, and when LabWindows wants to link rssmf_64.dll, I face the two following errors:
error: Undefined symbol '_CVI_GetFileSize@8' referenced in "d:\...\Release64\rssmf.obj"
error: Undefined symbol 'ProcessSystemEvents' referenced in "d:\...\Release64\rssmf.obj"
I checked the LabWindows installation folder, and in the "include" folder which contains many .h files, there are definitions for similar symbols as follows:
"userint.h" : int CVIFUNC ProcessSystemEvents(void);
"utility.h" : int CVIFUNC GetFileSize (const char fileName[], ssize_t *fileSize);
I add these .h files to the project but still get the same error. Could anyone please help me?
Best,
Nader
06-07-2019 04:13 AM
Hello NaderMostaan,
Does it works for other build configuration ?
Can't you use 32-bit version of LabVIEW and then compile the DLL for 32 targets ?
Have you tried with CVI 2017 ?
Regards
