LabWindows/CVI
Error undefined symbol '_CVI_GetFileSize@8' when trying to create DLL from instrument driver
Hi all,
I am trying to create 64-bit DLL for the driver of a device so that I can use it in LabVIEW 2014 64-bit. The information for the instrument is as follows:
instrument: Rohde & Schwartz SMF100A signal generator
Driver type: VXI plug&play
I have made a DLL project in LabWindows/CVI 2019 and loaded all the .c, .h and .fp files provided by Rohde & Schwartz as the LabWindows/CVI driver. When I try to build the project in the 'Release64' mode, and when LabWindows wants to link rssmf_64.dll, I face the two following errors:
error: Undefined symbol '_CVI_GetFileSize@8' referenced in "d:\...\Release64\rssmf.obj"
error: Undefined symbol 'ProcessSystemEvents' referenced in "d:\...\Release64\rssmf.obj"
I checked the LabWindows installation folder, and in the "include" folder which contains many .h files, there are definitions for similar symbols as follows:
"userint.h" : int CVIFUNC ProcessSystemEvents(void);
"utility.h" : int CVIFUNC GetFileSize (const char fileName[], ssize_t *fileSize);
I add these .h files to the project but still get the same error. Could anyone please help me?
Best,
Nader
(2,350 Views)
Hello NaderMostaan,
Does it works for other build configuration ?
Can't you use 32-bit version of LabVIEW and then compile the DLL for 32 targets ?
Have you tried with CVI 2017 ?
Regards
(2,285 Views)
