Exit Prompt Popup
What values are returned, or how can I detect when a promptpopup is exited instead of entering information?
Thanks!
(3,723 Views)
Accepted by TurboMetrologist
You receive the return value VAL_USER_CANCEL if the operation has been canceled, i.e. closed the popup with the red X instead of the OK button.
You can check the string length of the response buffer to see if the user did enter anything.
(3,719 Views)
Thanks!
(3,716 Views)
