LabWindows/CVI
How can I display more than 2500 lines of text?
I need to read in large text files, allow the User to edit them, then store the modified text back on the hard disk. I thought I could just use a "text box control", but I found the followin in the help file:
A text box can have only a limited number of lines. The number of lines multiplied by the pixel height of the font must be less than 32,767, or else the text box does not scroll. In a text box that uses NIDialogMetaFont or NIEditorMetaFont, you can have a maximum of about 2,500 lines.
My text files could be up to 256K lines. Any suggestions on how I could do this?
Jeff Smith
Northrop Grumman Corp.
(3,211 Views)
You could use an ActiveX text box control if you have CVI 6.0. I don't think the Microsoft Rich Text Box has that limitation. Also, you could actually use a textbox with your own scroll bar control (cvi\toolslib\custctrl\scroll.fp) And only load parts of the file from a buffer into the text box based on the position of the scroll bar.
Best Regards,
Chris Matthews
(3,211 Views)
Which version of CVI are you using? Because that limitation of text boxes has already been removed a couple of versions ago (version 5.5, if I'm not mistaken)
Luis Gomes
NI
(3,211 Views)
