How can i ommit the unwanted strings from the buffer..?
    Hi i have send the string to a device for example "RG_status" and "RG_RPM" and so and so..
    i get readout the response from that device. My problem is..,
    I want only the Response from the device, but the buffer contains both the string and response...
    How can i extract only the response ..
    I am using the ComRd() and ComWrt()
   Forexample,
         char *ch[2];
         int i=1;
         ch[1]="RG_Stauts";
         ch[2]="RG_RPM"; //Rotation per min of the device
         In timer,
              ComWrt(comport,ch[i],StringLength(ch[i]));
              bytes_read=ComRd(comport,read_data,read_cnt);
              CopyString(display,o,read_data,0,bytes_read);
              SetCtrlVal(mypanel,PANEL_NUMERIC_1,display);
             //-----missing here//
                 SetCtrlVal(mypanel,PANEL_NUMERIC_2,display);
                 i++;
      I get,
             *RS_Status
             1
             *RS_RPM
             1000
      In the read_data buffer,
           Now i would like to display only the corresponding values of the strings in the panel...
      What i am missing..???
      Please help me.
   Thanx in advance,
   venki
(2,887 Views)
Is your remote RS232 device configured to echo any strings that it receives? If so this would cause exactly the symptoms you describe.
JR
(2,879 Views)
