How do I display both printable an non printable ascii chars from a device and display it in a text box?
My UUT sends to my computer via serial port both printable and non-printable ascii characters. The question is:
1)   how do I display all those characters in a text box.
2)   how do I display all those characters in hex format and display in a text box?
Thank you.
Robert
(4,397 Views)
Accepted by Robert_Mensah
Textboxes actually can receive strings with both printable and non-printable characters: non-printable characters will be represented with a little square. Consider for example this code:
    char    a[512], msg[512];
    // Create a string with embedded non-printable characters
    sprintf (a, "Hello :%c%c%c%c%c: world!", 1, 2, 3, 4, 5);
    // Pass the string to the textbox "as is"
    ResetTextBox (bH[1], b1_n, a);
    //Format a hex representation of the string and add to the textbox
    Fmt (msg, "\n%*d[zb1r16w2p0j1] ", strlen (a), a);
    SetCtrlVal (bH[1], b1_n, msg);
Result is as follows: the first line is the string passed "as is", the following is the hex representation.
Message Edited by Roberto Bozzolo on 02-17-2009 09:18 AM
(4,385 Views)
Thanks for the code snippet. That helped.
Robert Mensah
(4,356 Views)
