09-01-2011 10:23 AM
How do you change the tab outline color? I wish to use a black style on my test program but the tab features have a white edge on the top and left sides to try and give a 3d look. I've tried playing with the windows style but had no success. Does anyone know how to remove this or change the color? The closest I have got so far is setting a windows 7 basic theme which removes the 3d look. This does however give a white background on the tab pages which I cannot find a way of changing in either CVI or windows. Any suggestions?
Solved! Go to Solution.
09-01-2011 01:44 PM
Chris,
Unfortunately, this border is only customizable through the Windows theme. Changing the theme to the basic is likely going to be the closest to what you are looking for without creating a custom theme for Windows.
09-02-2011 01:48 AM
I have tried changing the theme but then the 'body' of the tab turns white and stays white. Do you know what part of the windows theme changes this attribute?
09-02-2011 06:13 PM
Chris,
It looks like this is not configurable with the Windows Styles. Sorry, I think you are stuck with a border.
09-05-2011 01:54 AM
Ok. Thanks for the help.
