LabWindows/CVI
How to capture a .gif file from a spectrum analyzer and save the file in PC
so can you 'talk' with your instrument at all, using CVI? viOpenDefaultRM () and viOpen () did succeed without error? Phrased differently, does your communication (using CVI) work except transferring binary data?
Message 11 of 12
(1,638 Views)
Thank God,   I found the problem,  before i use Labwindows 2012, when i turn to CVI 2013,  i can read data from the instrument successfully.
Message 12 of 12
(1,635 Views)
