LabWindows/CVI
How to create an array Station Globals programmatically in CVI?
Hello all,
I want to create an array Station Globals programmatically in CVI. Where can I find some examples?
Zhonghui Ning
(4,323 Views)
Zhonghui,
There is a KnowledgeBase on our website that describes the methods needed to do this. You can find the KnowledgeBase at http://digital.ni.com/public.nsf/websearch/C7C81F4AE5A46BB686256CDA005FA4C6?OpenDocument.
I found this by searching for "teststand create variable". You can find TestStand examples on our Developer Library by going to http://www.ni.com/devzone and clicking on the link for Developer Library. This page has example code as well as tutorials and application notes on many aspects of TestStand. There are quite a few examples there that already address this type of question: Creating Sequence File Global Variables Using the TestStand API with LabWindows/CVI
and Creating and Inserting a New Data Type into a Sequence File using LabWindows/CVI
We continually add examples to these web pages, so it is always a good place to look for examples. While they may not have the exact answer to your questions, the examples usually cover a topic that is close enough for you to be able to apply the example to your question.
Hope that helps.
Shannon R.
Applications Engineer
(4,323 Views)
Hello Shannon,
Thanks for your help. TS_PropertyNewSubProperty() can work in my project. It can successfully create an teststand dynamic array by the following first statment.
TS_PropertyNewSubProperty (myglobals, NULL, "Array", TS_PropValType_String, VTRUE, "", 0);
TS_PropertySetValStringByOffset (myglobals, NULL, 0, 0, newValue);
I want to assign newValue to the first element of the StationGlobals Array by the above second statement. It doesn't work.
Do you have any example about assigning values to a teststand array programmatically? If there are no extra website for assigning values to a teststand array, I will continue to study the website you have told me.
Zhonghui
(4,323 Views)
Just for future reference.
You can do this:
// create the global if it does not exist
tsErrChk(TS_PropertyNewSubProperty (TS_Globals, NULL, "globalname", TS_PropValType_Number, VTRUE, "", 0));
// get a property object reference to the new global that was created
tsErrChk(TS_PropertyGetPropertyObject (TS_Globals, NULL, "globalname, 0, &MyGlobal));
// Set the size of the array
tsErrChk(TS_PropertySetNumElements (MyGlobal, NULL, numElements, 0));
 // set a value
tsErrChk(TS_PropertySetValNumber(TS_Globals, &errorInfo, "globalname[0]", 0, 2));
CA_DiscardObjHandle(MyGlobal);
//Release Object
CA_DiscardObjHandle(TS_Globals);
To copy a full array over use the following example:
C:\Users\Public\Documents\National Instruments\TestStand 2010 SP1\Examples\AccessingArraysUsingAPI\UsingCVI
Jacob R. | Applications Engineer | National Instruments
(3,745 Views)
