Helpful but not what I was looking for. The ROIs need to be able to be reshaped by a user, then the dimensions of the ROI need to be able to be saved and latter restored and recreated. So, lets say that you have some circular image on the Imaq window. Using the draw tools, I create a circlular ROI that surrounds the circle somewhere on the window, I would like to be able to save the attributes of the ROI and be able to recreate it latter in the same spot on the window. This is a laser beam profile application and I move my camera to other places and then back to the original and the beam should show up within the restored ROI almost in the exact place (because of beam apertures). I have several places that I want to move my camera to and create an ROI for every pos
ition, then when the camera is moved to a specific spot using a button press, I can restore the previously saved ROI for that particular spot. Make sense?
Tom Zajicek
