How to show the log line in graph?
Dear Sir/Madam:
Please see the attachment file first, when I set the graph in "Log Scale", I can see the log line in the *.uir, However, when I run the program and plot the waveform, I can't see the log line.
could you help how to set and see the log line?
Mike Cheong
(3,374 Views)
Can you check to see which version of CVI, and which version of the CVI run-time engine (c:\windows\system32\cvirte.dll) you have installed in your machine?
Luis
NI
(3,356 Views)
Hello Mike,
Our recommendations are going to be dependent on the version of CVI you are using, but in the meantime, you can also take a look at Luis' comments on the following post: http://forums.ni.com/ni/board/message?board.id=180&message.id=15462&requireLogin=False
Wendy L
LabWindows/CVI Developer Newsletter
(3,337 Views)
Dear Wendy L,
After I refered to the link, I know how to do it!
Thanks very much!
Mike Cheong
(3,331 Views)
