How to use void pointer in function
I am trying to convert float/int/str information to string and store in an array.  Can I use a single function to do that?  I am getting errors under Labwindows
82, 34 error: invalid operands to binary expression ('float *' and 'float')
I think I didn't use void pointer correctly, but why?  Thanks ahead.
main{
TestReport(Test_Description, 0.2,&MeasureValue,0.4, TESTREPORT_FORMAT_FLOAT,"Volt");
int TestReport(char description[], float Lowlimit, void *Result, float Highlimit, char datatype,
char unit[])
char TempTest[256];
strcat(Test_Report_Text, description); //report item header
switch (datatype){
case TESTREPORT_FORMAT_INT:
if (((int *)Result > (int)Lowlimit)&&((int *)Result < (int)Highlimit)) strcat(TempTest, "Pass");
strcat(TempTest, "*Fail");
break;
case TESTREPORT_FORMAT_FLOAT:
if (((float *)Result > Lowlimit)&&((float *)Result < Highlimit)) strcat(TempTest, "Pass");
break;
case TESTREPORT_FORMAT_STR:
break;
strcat(Test_Report_Text, TempTest);
return 0;
(5,395 Views)
Accepted by SilverMan
The error is quite clear: you cannot compare a pointer (float *) to a float value. You should modify your expression this way:
if ((*(float *)Result > Lowlimit) && (*(float *)Result < Highlimit)) strcat (TempTest, "Pass");
Beware that the same applies to the int case: you don't get a warning since a pointer effectively is an integer value, but you are actually comparing the pointer (=address) value with the limits instead of the actual value of the variable addressed from the pointer.
(5,372 Views)
Hi RobertoBozzolo,
Thank you so much for answering the questions, it is working now.  But I have an additional question:
In the function which contains the void * variable, I found in C language I have to use a extra variable in order to get the correct value(other than directly using the pointer variable). For example:
float Temp = *(float *)Result;
if(Temp > Lowlimit) do something;   //this will work
if(*(float *)Result > Lowlimit) do something; //this will not work
Can anyone explain why I have to the variable indirectly?
Thank you!
(5,355 Views)
I'm not aware of such a constraint: the code as I wrote should work correctly. Did you find some problems?
(5,341 Views)
if I directly use the code:
 it wouldn't work.
Unless I store the float value into another variable first and then it will work as it it suppose to be.
float tempresult = *(float *)Result;
if (tempresult > Lowlimit) && (temp < Highlimit) strcat (TempTest, "Pass");
I am just curious why the first line of code doesn't work, in my understanding, both types of C code have the same interpretation.
(5,305 Views)
What kind of error/behavior are you getting?
(5,295 Views)
How about when you try:
if (((*(float *)Result) > Lowlimit) && ((*(float *)Result) < Highlimit)) strcat (TempTest, "Pass");
It should be equivalent according to the C operator precedence standard, but this would make sure it is not some operator precedence messup.
Rolf Kalbermatter  My Blog
(5,243 Views)
