Is there a way to rename a directory ?
thanks a lot.David
(3,485 Views)
David,
Do you mean to rename a directory that already exists on one of your drives, or rename the directory of where a distribution kit is installed, or possibly something else? If the first, I think the best way to do that would be to incorporate the Windows SDK functions into your project, because the only functions I can see that are similar to that in CVI are MakeDir() and SetDir(), but neither will change an existing name.
(3,485 Views)
Was the first one.
Thanks for the answer, Im gonna try to use Windows SDK...
(3,485 Views)
well, why dont you execute the DOS command "ren" using the LaunchExecutable function?
you may read the function help for the usage.
(3,485 Views)
