ā10-19-2012 01:24 PM
Will a LabWindows CVI compile to cRIO?
Can you write an entire program in LabWindows CVI and not write any code in the graphical LabView?
ā10-22-2012
03:13 PM
- last edited on
ā11-17-2025
11:17 AM
by
Content Cleaner
Unfortunately CVI does not support full application development for the CompactRIO. However, there is a C API to LabVIEW FPGA. The following links provide some additional information on the capacibilities of CVI with the cRIO.
C Interface to LabVIEW FPGA
https://forums.ni.com/t5/NI-Labs/C-Interface-to-LabVIEW-FPGA/td-p/830645
NI-RIO extension for interface with C API:
http://joule.ni.com/nidu/cds/view/p/id/2616/lang/en
How-To Build FPGA Host VI in C API:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x5DNCAY&l=en-US
ā05-02-2017 10:03 AM
I need to develop API in LabWindow CVI with Real time to control the cRIO
up to now I had no success and I need some help, and sample program in LabWindow CVI to accomplish this task.
ā05-03-2017
08:55 AM
- last edited on
ā11-17-2025
11:18 AM
by
Content Cleaner
Hi Dunja,
I am not sure where you are at in your setup process, but the getting started guide linked below gives in-depth instructions on setting up your RT system.
Getting Started with the LabWindows/CVI Real-Time Module
You can also use the NI Example Finder to find examples in LabWindows/CVI, which are available by selecting Help»Find Examples in LabWindows/CVI, to browse or search for example programs. You also can access the example programs from the samples\CVI samples\realtime directory.
If you have other questions, please create a new post as this post is about five years old and is not easily visible on the forums.
Josh
Applications Engineer
