I have an issue using max when I try to build a scale for my measurement,
I have a voltage acquisition + 5v to - 5v and my scale must be -5v = 0 RPM, 5v = 7500 RPM I tried to build a scale for this using linear scale so the transfert function is Y(RPM) = 1500X(v), I also tried to use a map range scale withe the values above but I get an error when I save the task "error -200077 occured a DAQ Assistant Possible Reasons: property AI.Min
requested -5; value begin with 0 ; values end with 7500"
Even if I don't get any error on the linear scale The larger value I can get is 322.9474 RPM I cannot go further and curiously when I am not using any scale the voltage value can go over 1(V) which according to the scale calcul will give 1500 RPM
I don't understand why RPM value using scale from V to RPM is stuck under 322.9474 RPM, maybe I did not build my scale correctly...
Thanks for answers
Olivier
