LabWindows/CVI
Menubar not display on .uir
I'm on Win7 platform. My menubar is only display aft i run the LoadMenuBar() function. I wish to see it during edit mode too.
(2,991 Views)
Accepted by distinctlyme
When setting panel attributes in the UIR editor you can associate a menubar to it: this way the menubar is displayed on the panel while editing the UIR.
At runtime, you no longer need to load and install it on the panel with LoadMenuBar. In case you need to retrieve its handle to access menu functions you can use GetPanelMenuBar function.
(2,987 Views)
Thanks. Did double clicking to open that box.
(2,979 Views)
