More CPU usage when the UIR file gets open
Hi all,
When I open cvi workspace file without uir the CPU usage is around 30%. As soon as the uir file is opened the CPU usage goes to 90% even though I am not running the code. My system has Pentium 4 processor and ram of 2 GB. I am using CVI 2009. Can anyone tell me what is causing the more CPU usage?
(3,482 Views)
Does the usage increase when the editor is in operate mode, or also in edit mode?
Does the usage increase when any .uir is open (with the CVI example programs, for example), or only with this particular .uir?
Does your .uir have timer controls?
Luis
(3,470 Views)
The editor is in edit mode.
I have a timer control in uir with an interval 0f 25 milli seconds. The cpu usage came down when I removed the timer. So timer may be causing the more cpu usage?.
(3,465 Views)
Yes, it may. Although I'm a bit surprised that a single timer would cause that large of a difference. Does the effect vary with the timer interval?
(3,454 Views)
This should help Smiley Happy
http://digital.ni.com/public.nsf/allkb/7F7C673F921B9099862564C60061E2EC
-Avichal (C.L.A.D)
(AE, NI India)
(3,447 Views)
