02-05-2003 09:15 PM
02-10-2003
10:17 AM
- last edited on
07-24-2025
09:25 AM
by
Content Cleaner
Hello
The application font should just map to the the arial font on your system.This is to ensure that if you are using the same application across different systems, that all of the GUI's should look the same, since they are all accessing the same font all the way thru. How are they looking different? And are these pc's with the same os? could you attach a snapshot of the problem?
To see where you can set the values of the default fonts, check out pg 6 of 203 of the Measurement Studio LabWindows/CVI User Manual
Bilal Durrani
NI
02-10-2003 09:39 PM
02-11-2003 06:58 PM
07-18-2003 07:06 AM
