OPC UA architecture
Yes.
Could you double check that at the very beginning of .c and .h file you see something like
/* THIS IS A SINGLE-FILE DISTRIBUTION CONCATENATED FROM THE OPEN62541 SOURCES
 * visit http://open62541.org/ for information about this software
 * Git-Revision: v0.2.2
It's necessary that Git-Revision is v0.2.something
You can't compile v0.3 with CVI.
Which kind of compilation errors do you see?
Vix
Using LV from 7
Using LW/CVI from 6.0
Message 21 of 57
(6,446 Views)
doesn't find this file:
# include <stdbool.h> /* C99 Boolean */
# include <malloc.h>
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 22 of 57
(6,446 Views)
To use C99 extensions you must enable them in CVI.
Options >> Build Options...
and enable "Build with C99 extensions"
Vix
Using LV from 7
Message 23 of 57
(6,443 Views)
This is my setting, i'm using CVI 2012
Message 24 of 57
(6,441 Views)
I forgot to say that you must use CVI 2013 or later.
Since CVI 2013 an almost-standard porting of clang compiler is used and this allows you to use standard third party libraries.
I suggest either CVI 2015 or CVI 2017 (since CVI 2013 is full of bugs).
Based on my experience, a version older than CVI 2015 is not usable nowadays (except for old legacy projects built and maintanined with old CVI).
Vix
Using LV from 7
Message 25 of 57
(6,439 Views)
I've Tryed CVI 2017 evaluation but get other problem.
Message 26 of 57
(6,427 Views)
These are objects and functions from Windows SDK.
After you install CVI 2017 you must download and install Windows SDK (8.1 unfortunately).
Vix
Using LV from 7
Message 27 of 57
(6,425 Views)
i've downloaded from this link the windows 8.1 SDK setup, this started a downloader from where i get the installer
and after running the installation i have this page but still doesn't compile with the same problem
i'm using Windows 7 64 bit
Message 28 of 57
(6,421 Views)
You have to install SDK through CVI installer, because it copies the relevant files where necessary.
If you download and install it with its own package, CVI isn't able to see it.
Otherwise it would be possible installing a newer version of the SDK and configuring CVI so that it uses it Smiley Wink
Vix
Using LV from 7
Message 29 of 57
(6,419 Views)
Nothing to do, tryed to repair the installaion of this components:
  • MSDTRedistributables_WindowsSDK_81
  • MSDTRedistributables_BuildTools_81
  • MSDTRedistributables_SDKHeaderFiles_81
but still have the same problem compiling.
i've tryed to create a new project with only this file in it and also doesn't compile.
Message 30 of 57
(6,406 Views)
