Out-of-bounds pointer argument (past end of memory block)
I write a program to control power supply. One of funtions is to set voltage and current in the table.
When i run it, it shows the below error message:
"Out-of-bounds pointer argument (past end of memory block)"
Could someone help me with this?
Thank you!
This function code is under below:
int CVICALLBACK SetValueCallBack (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
    switch (event)
        float Voltage_Set, Current_Set;
        int TimeSet;
        int RowSet;
        char VoltageSetBuff[30];
        char CurrentSetBuff[30];
        case EVENT_COMMIT:
            GetCtrlVal(panelHandle, PANEL_SETVOLTAGE, &Voltage_Set);
            GetCtrlVal(panelHandle, PANEL_SETCURRENT, &Current_Set);
            GetCtrlVal(panelHandle, PANEL_SETTIME, &TimeSet);
            GetCtrlVal(panelHandle, PANEL_SETROW, &RowSet);
            sprintf(VoltageSetBuff, "%2.2f", Voltage_Set);
            sprintf(CurrentSetBuff, "%2.2f", Current_Set);
            SetTableCellVal(panelHandle, PANEL_TABLE, MakePoint(1, RowSet), VoltageSetBuff);
            SetTableCellVal(panelHandle, PANEL_TABLE, MakePoint(2, RowSet), CurrentSetBuff);
            SetTableCellVal(panelHandle, PANEL_TABLE, MakePoint(3, RowSet), TimeSet);
            break;
    return 0;
(6,740 Views)
Sorry, I forget to say the error appears in "SetTableCellVal(panelHandle, PANEL_TABLE, MakePoint(2, RowSet), CurrentSetBuff);".  Thank you!
(6,737 Views)
Accepted by a710756
I'm able to reproduce the issue, though I'm seeing the problem on the line just before the one you mention. I think this is likely because variables declared inside a switch statement before the case labels are not initialized the same way that other variables are.* If you move those variable declarations out before the switch, I think you'll find that your errors go away:
    int TimeSet;
    int RowSet;
    switch (event)
        case EVENT_COMMIT:
I'll file a bug report to make sure this gets further investigated.
* Note that by the C language rules, even an explicit initialization (e.g. int TimeSet = 10;) at that position inside the switch has no effect!
Mert A.
(6,703 Views)
Thank you, Mert A.
(6,688 Views)
How about at least a  compiler warning stating "unreachable code"?
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(5,994 Views)
