Picture ring animated control spinning problem
The picture ring animated control is not spinning for me as expexted.
In my main function after displaying the panel
AnimateCtrl_ConvertFromPictRing (panel, PNL_SPLASH_ANIMATION);
AnimateCtrl_SetAttribute (panel, PNL_SPLASH_ANIMATION,
ATTR_ANIMATE_ENABLED, 1);
ATTR_ANIMATE_FRAME_INTERVAL, 0.05);
AnimateCtrl_SetAttribute (panel, PNL_SPLASH_ANIMATION, ATTR_ANIMATE_STOP_ON_LAST_FRAME, 0);
ProcessSystemEvents();
ProcessSystemEvents() line it is giving a runtime error
NON-FATAL RUN-TIME ERROR: "test.c", line 137, col 5, thread id 0x00000C38: Library function error (return value == -4 [0xfffffffc]). Panel, pop-up, or menu bar handle is invalid.
Can anyone help me out with this?
(3,520 Views)
Accepted by SriVidya
1) The first thing to do is to include error checking. All functions you use provide a return value, but you prefer to ignore it. It's better, i.e. safer to check each function for proper operation. Instead of AnimateCtrl... use
status = AnimateCtrl...
if (status < 0 )...
2) The error returned 'Panel, pop-up, or menu bar handle is invalid' indicates that either panel is not a panel handle or 'PNL_SPLASH_ANIMATION' is not a valid picture ring control. Are these the constant names as defined in the include file of your UIR file?
(3,512 Views)
