 songyg6397
			songyg6397
			03-10-2017 02:03 AM
After reinstalling the windows, labview program, "Ressistance.vi", dose not work with
"Error 8 occurred at Open/Create/Replace File in Write Spreadsheep String.Vi -> Write To Spreadsheet File (DBL).vi. File permission error. You do not have the correct permission for the file. C:\238.dat".
I think there is a problem with the storage root.
So, i want to modify the labview source of "Resistance.vi" using the source of "Test.exe".
However, we can not deal with the labview program and code.
Please help me to use this program without the "238.dat".
 RobertoBozzolo
			RobertoBozzolo
			03-10-2017 06:49 AM
Hello, this is the wrong board where to discuss LabVIEW VIs since this forum is dedicate to LabWindows/CVI users. The correct forum is here.
Having said this, a file permission error can either be solved by granting permission to the target folder and/or file or moving the file to another folder; I suggest you to choose this option since in the more recent versions of Windows using the root path is deprecated. You could change frame 0 of your sequence to point to another folder where to locate your data file, after checking to have permissions to that specific folder.
 RobertoBozzolo
			RobertoBozzolo
			03-10-2017 10:03 AM
I see that you already posted a very similar question on the same program a while ago and got an answer.
Please try not to post multiple times the same question as it becomes difficult to follow up with the discussion!
