LabWindows/CVI
Ring control popup menu positioning
When I left click in a ring control, a popup appears listing all the possible selections.
The location of this popup varies (see the attached word file) and may even be off the visible screen area.
I would like to be able to specify where the popup appears relative to the ring control.
Is there any way of doing this.
No source code attached as I do not think this is relevant.
Platform: Windows 10 (up to date).
Compiler: LabWindows/CVI 2013 Version 13.0.0 (632)
(2,693 Views)
Accepted by DerekLivsey
Hello Derek,
It is a bug  of CVI2013 running in Win10.
Solution:
- Locate cvi.exe on your hard drive (c:\Program Files\National Instruments\CVI2013\cvi.exe),
- right-click,  Troubleshoot Compatibility
- Select option 2
- Check "The program is not displaying correctly"
It will activate a compatibility option for ppp rescaling.
You can cjheck directly this option in cvi.exe shortcut, right-click, Properties, compatibility:
PS: Sorry my operating system is in french, so I can't write exact terms of an english windows 10.
(2,660 Views)
Many thanks, that fixed it!
(2,632 Views)
Wonderful solution. Thank you!
(1,717 Views)
