Rohde & Schwarz NRP Z81 power meter not initializing in Labwindows CVI
Hi, I am having trouble with initializing my R&S NRP Z-81 power meter using LabWindows. LabWindows is detecting the power meter and when the SSessionInfo typedef struct is called the IsPulseMeasurementOn boolean value is true. But i am stuck in an infinite loop as the IsMeasurementComplete boolean value does not turn true. I am debuging in TestStand. If anyone has any idea where I am going wrong or just some inputs on what i could try i would greatly appreciate it. Thanks in advance..
(5,944 Views)
I would like to add that the power meter is working fine when tested with the NRP toolkit.
(5,943 Views)
Did you try the R&S examples for measurements to get started wiht the NRP-Z programming http://www.rohde-schwarz.de/de/service_support/downloads/treiber/?type=25&downid=1255
br j.
(5,917 Views)
So you used the driver that you can download from that website, right?
http://www2.rohde-schwarz.com/en/service_and_support/Downloads/Drivers/?downid=1598
You could also have a look to the document How to use the R&S®NRP-Z Instrument Drivers which could help you.
If you still have some trouble, could you please send us the sequence that your using?
regards
(5,911 Views)
Thank you so much for your replies. Yes I did try out the example measurment codes provided by R&S and they work fine. And yes i have downloaded and am using the latest drivers from the R&S website. I am still unable to figure out where I am going wrong. I have attached the seq file i am using incase thats of any help. Thanks once again.
__
(5,896 Views)
Accepted by sinnas
Just to inform you that the problem was with a difference in variable types between LabWindows and TestStand.
(5,861 Views)
Hello I would like to know how did you connect the R&S Z81 power sensor to the Labview environment, did you use a DAQ and which one?
(4,773 Views)
