09-19-2007 03:05 PM
Solved! Go to Solution.
09-20-2007 05:23 PM
09-20-2007 05:37 PM
09-21-2007 02:17 AM
Hello Asic,
just letting you know that I am dealing with the same problem. On some systems the box is there, on most systems not. Even with the same CVI application. When the user closes the box, the application just quits... ![]()
09-21-2007 11:28 AM
09-21-2007 12:07 PM
Thanks Luis,
You are correct.... this is a DUAL monitor system, all of my systems are Dual monitor so I guess if I position my monitors in the correct configuration, this box would be off screen...
Chip
09-24-2007 06:50 AM
09-23-2010 08:59 AM
No longer an issue with 2009 "Ding Dong the Box is Gone!" ![]()
Cheers!
Chip
