LabWindows/CVI
Saving new exe file for existing program
My name is Haim and I'm mechanical engineering student, who had recently started using CVI.
I have  a program called 'XYZ' and all it files including the exe is called the same.
I know there is a way using the save is... to save new uir, c and project files,
But, is there any way to save a new exe file'ZYX' (for example), so that any time i will run the program in CVI (including debugin),
it will generate the new exe?
Thanks in advance
Haim
(4,334 Views)
Accepted by Haim1404
The file that is generated when you create an executable takes the name set in Build 》Target settings panel. You can set a different name for each mode (Debug, release and the correspondig 64bit options)l
(4,331 Views)
Thanks alot RobertoBozzolo!
(4,324 Views)
managed to find all except cws.
any idea?
never mind I guess I can just rename it using right click.   Smiley Wink
(4,306 Views)
