LabWindows/CVI
TUI loads different than UIR
Hi! I noticed some curious behaviour regarding UIR/TUI files.
I use the "save uir as tui" option, so every time I make a change in my uir that results in a new tui file. However, I have noticed that some of my components are not placed correctly in the tui file. In particular, some text boxes are shifted to the right. (I attached an example to this post.)
What's up? Is this a known issue or am I doing something wrong when saving the uir file? Has anyone else encountered this?
Thanks!
(1,058 Views)
can you provide your UIR file?
I believe it should be related to textbox sizes.
(981 Views)
Absolutely. Here's a small example.
(961 Views)
