LabWindows/CVI
Two UIR's two monitors- how can I load them on separate monitors?
I have a two (2) UIR's that contains multi-up test data.  My test setup has dual monitors.  How can I load one UIR on the first monitor and the 2nd on the other?  they only method I found is to set the panel location (Left position) to a number that will push it off the first monitor onto the 2nd.  Is there a better way to do this?
(2,403 Views)
Accepted by Joncombat
some earlier discussion on the issue can be found here: https://forums.ni.com/t5/LabWindows-CVI/Opening-Panels-on-a-Second-Monitor/td-p/188099
May be it solves your issue
(2,363 Views)
