LabWindows/CVI
Uninstalling CVI2013 not convincing
Today I have uninstalled CVI2013 SP1, i.e., all NI software except the Update service, see Fig. 1 below. However, looking at the files and directories left after de-installation I am, hm, disappointed... Why is so much left over, see Fig.2 below...?
Should I clean it manually / is it safe/recommended to clean it manually?
Fig 1: After Uninstalling CVI2013 everything looks fine
Fig.2: Everything? Well, not really... why are these directories not cleaned and removed during de-installation? I don't think they are needed for the update service...
(5,093 Views)
Hi Wolfgang,
you can use the msiblast registry cleaner to remove the remaining files.
msiblast can be downloaded from several sources on the web.
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(5,071 Views)
Hello, Wolfgang,
I will talk this over with our installers team, and post here when I have information on why those specific files are being leaked on uninstall.
Melanie,
MSI blast is an unsupported tool, which can leave the system in a bad state. It is not recommended that anyone use it to uninstall NI Software.
Thank you,
Daniel Dorroh
(5,061 Views)
Thanks...
(5,041 Views)
Some additional information:
After de-installing NI Update Service the number of files has decreased remarkably (but still is not zero), see below.
It appears that patches are not de-installed with the product but with Update Service, e.g. for CVI the patch f1...
(5,024 Views)
