LabWindows/CVI
Variable as string
Dear all,
I have a question for programming  an issue with C/Labwindows  and I need a help if it is possible.
I have consts named : A_0, A_1 and I would like to access to these const automatically. Meanning that I would like to create a const name wich is the result of concatination of the string «A_» with a number. The resulted concatination gives me the name of the const which I can use to access a position of an array for example.
Example :
Consts which already exisit :
#define A_0 0
#define A_1 1
#define A_2 2
#define A_100 100
I need to access to these consts automtically.
« A_» concatinated with «0», it gives a string « A_0 Â». Then the resulted string « A_0 Â» will be used as a const which I can use to access an array for example (Array[A_0]=0, Array[A_1]=1,…).
I would like to know if there is some ideas to do this feature.
Thank you so much for your answer,
Hapiest
(6,902 Views)
I would like to know if somone has an idea for the issue that I have described.
Thank you for your answer.
Hapiest
(6,858 Views)
I dont' think yoo can obtain what you are describing: #define is a preprocessor clause that is evaluated at compile time (not at runtime) substituting the macro name with the corresponding value before compiling and linking the program.
The closest method I can think of is some form of array type that you can use by its index, but with no additional information on what is your goal it's hard to design a real system.
(6,849 Views)
The real system is:
I have many(100) check box object in my user interface. When these check boxes are insered in the my interface, it will be a generation of thes const variables in the ".h" file, automatically (with #define...).
So the issue is that I would like check or uncheck these chek boxes following a variable value "v". If (v ==1), then I will check all the check boxes. If (v==0), then I will uncheck all the check boxes.
The name of check boxes are A_0, A_1.....A_99.
(6,839 Views)
Accepted by topic author hapiest
Did you consider using control arrays? See here or here?
Another possibility is to create the UI controls programmatically at run-time
(6,834 Views)
Control arrays suggested by wolfgang are a powerful tool indeed. They help solving several control addressing problems.
Before they were introduced you could simply create arrays of control ID'S and use them, this way:
int  ctl [100];
// fill in the array
ctl [0] = PANEL_CHECKBOX1;
CTL [99] = PANEL_CHECKBOX100;
// Use the array in a loop
for (i=0; i < 99; i++) {
  SetCtrlVal (panel Handle,  ctl [i], 1);
(6,816 Views)
Control arrays is what I am looking for!
Creating an array of controls resolves also the issue!
Thank you!
Hapiest
(6,778 Views)
