LabWindows/CVI
Very slow program execution without (unused) USB-Stick on DELL-PCs
we have a general problem, if our LabWindows V8.1 Software under XP  is executed on DELL-PCs (without USB-Stick; there are no function used by/with the USB-Stick). Program executions time is about 10 times slower, if the USB Stick is inserted. With inserted USB-Stick, program execution-times are ok.
With any other PC, an inserted USB-Stick does not cause this problem.
Any help would be appreciated.
Thank you in advance
Juergen
(3,244 Views)
Accepted by elektroniker
Do you have ReadyBoost enabled for the USB-Stick (Microsoft ReadyBoost)? I've never used this functionality before, but I suspect that it is possible for this to have a negative impact on your system performance.
(3,231 Views)
thank you very much for your help, but the problem still exists. Our customer still uses a USB-Stick in order to run his program.
Best regards
J. Turzer
(3,175 Views)
