LabWindows/CVI
Very slow program execution without (unused) USB-Stick on DELL-PCs
we have a general problem, if our LabWindows V8.1 Software under XP  is executed on DELL-PCs (without USB-Stick; there are no function used by/with the USB-Stick). Program executions time is about 10 times slower, if the USB Stick is inserted. With inserted USB-Stick, program execution-times are ok.
With any other PC, an inserted USB-Stick does not cause this problem.
Any help would be appreciated.
Thank you in advance
Juergen
(3,323 Views)
Accepted by topic author elektroniker
Do you have ReadyBoost enabled for the USB-Stick (Microsoft ReadyBoost)? I've never used this functionality before, but I suspect that it is possible for this to have a negative impact on your system performance.
(3,310 Views)
thank you very much for your help, but the problem still exists. Our customer still uses a USB-Stick in order to run his program.
Best regards
J. Turzer
(3,254 Views)
