LabWindows/CVI
Wordreport Class Not Register
I am using Wordreport.fp and Excelreport.fp out of the CVI2013\tooslib\activex directory.  When I run my application on the target machine I get an error "Wordreport Class Not Register".  So that means the ActiveX component has not been loaded.
Where do I find the ActiveX component?  How do I get it loaded onto the target machine?  Do I have to load Microsoft Office?
(5,636 Views)
Wordreport and excelreport are instruments which connect via ActiveX to existing Word or Excel installed in the system. That is to say; yes, you need to install the product in order to use those instruments.
(5,623 Views)
(5,603 Views)
