XML Nested Element HELP
HELP.
I am having problems creating this XML schema in CVI.
In particular, the creation of <chassis> and <slot> tags throws an error.
ie.
<chassis1> does not start the container, </chassis1> starts the container and there is no subsequent closing element (ie </chassis1>)
Could one provide example code to resolve my problem?
TIA.
<?xml version="1.0" ?>
<config1>
    <chassis1>
          <slot1>
               <element3>VALUE</element3>
               <element4>VALUE</element4>
               <element5>VALUE</element5>
          </slot1>
          <slot2>
              <element7>VALUE</element7>
               <element8>VALUE</element8>
              <element9>VALUE</element9>
          </slot2>
      </chassis1>
      <chassis2>
          <slot1>
          </slot1>
          <slot2>
          </slot2>
      </chassis2>
</config1>
Message 1 of 9
(5,444 Views)
ChetK,
What error message is it throwing, and can you post a snippet of your code which is throwing this error?
Kyle Mozdzyn
Applications Engineering
Kyle M.
Message 2 of 9
(5,420 Views)
Thank you for looking into this:Smiley Very Happy
I get: line 95: XML Error: -2147352567
#include "cvixml.h"
#include <userint.h>
#include <formatio.h>
#include <ansi_c.h>
#include <cvirte.h>
void CreateXML(void);
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
 CreateXML();
 return 0;
void CreateXML()
 /*  Desired XML Schema
 <Rack>          <-rootElem*
  <Chassis0>        <-Elem1*
   <Fan1Present>0</Fan1Present>
   <Fan2Present>1</Fan2Present>
   <Fuse1>0</Fuse1>
   <Fuse2>0</Fuse2>
   <Slot0>        <-Elem2*
    <Board0>1</Board0>    <-Elem3*
    <Board1>0</Board1>
    <Board2>1</Board2>
   <Slot1>        <-Elem2*
    <Board1>0</Board1>
    <Board2>1</Board2>
  </Chassis0>
  <Chassis1>
   <Fuse1>0</Fuse1>
   <Fuse2>0</Fuse2>
   <Slot0>
    <Board0>1</Board0>
    <Board1>0</Board1>
    <Board2>1</Board2>
   <Slot1>
    <Board0>1</Board0>
    <Board1>0</Board1>
    <Board2>1</Board2>
  </Chassis1>
 </Rack>
 //File reads would be replaced with micro-controller queries
 //to interrogate variable rack/chassis configurations
 // * XML Element pointer
 char line[100],rline[100];
 int a,b;
 FILE *fp1;
 FILE *fp2;
 CVIXMLStatus stat;
 CVIXMLDocument doc;
 CVIXMLElement rootElem,Elem1,Elem2,Elem3,Elem4;
 //Build XML file
 stat=CVIXMLNewDocument ("Rack", &doc);
 stat=CVIXMLGetRootElement (doc, &rootElem);
 //Get MF Header
 for (a=0;a<2;a++)
  //Fixed # Chassis Items
  stat=CVIXMLNewElement (rootElem, -1, "Chassis", &Elem1);
  stat=CVIXMLNewElement (Elem1, -1, "Fan1Present", &Elem2);
  stat = CVIXMLSetElementValue (Elem2, "0");
  stat=CVIXMLNewElement (Elem1, -1, "Fan2Present", &Elem2);
  stat = CVIXMLSetElementValue (Elem2, "1");
  //Variable # Chassis items read from file #1
  //if items not present, don't write XML keys
  fp1 = fopen("file1.txt","rt");
  if (fp1 != NULL)
   while (fgets(rline,50,fp1))
    stat=CVIXMLNewElement (Elem1, -1, rline, &Elem2);
   fclose(fp1);
  //Variable # Slot items read from file #2, (2) slots per chassis
  //if slots not occupied, don't write XML keys
  for (b=0;b<2;b++)
   fp2 = fopen("file2.txt","rt");
   if (fp2 != NULL)
    Fmt(line,"%s<%s%d","Slot",b);
    stat=CVIXMLNewElement (Elem2, -1, line, &Elem3);
    while (fgets(rline,50,fp2))
     stat=CVIXMLNewElement (Elem3, -1, rline, &Elem4);
     stat = CVIXMLSetElementValue (Elem4, "0");
    fclose(fp2);
 CVIXMLDiscardElement(Elem1);
 CVIXMLDiscardElement(Elem2);
 CVIXMLDiscardElement(Elem3);
 CVIXMLDiscardElement(Elem4);
 CVIXMLDiscardElement(rootElem);
 CVIXMLSaveDocument (doc, 0, "test.xml");
 CVIXMLDiscardDocument(doc);
FILE1::
Fuse1
Fuse2
FILE2::
Board0
Board1
Board2
Message 3 of 9
(5,416 Views)
This is the output as viewed in IE:
- <Rack>
- <Chassis>
- <Fuse2>
  1
- <Slot0>
  <Board2>0</Board2>
  </Slot0>
- <Slot1>
  <Board2>0</Board2>
  </Slot1>
  </Fuse2>
  </Chassis>
- <Chassis>
- <Fuse2>
  1
- <Slot0>
  <Board2>0</Board2>
  </Slot0>
- <Slot1>
  <Board2>0</Board2>
  </Slot1>
  </Fuse2>
  </Chassis>
  </Rack>
Message 4 of 9
(5,415 Views)
I modd'ed the XML schema from the original post but the structure is the same...
-Chet
Message 5 of 9
(5,414 Views)
ChetK -> JolleyRogers (?? 2 profiles)
Spoiler
alias
Message 6 of 9
(5,411 Views)
Accepted by ChetK
The reason you get the exception is because rline - the string you read from your file has invalid character (0x0A) and you cannot create XML tags with this character. You can remove this using the RemoveSurroundingWhiteSpace toolbox function. Also, I noticed that your code does not really map to the schema in your comments - you are using Elem2 instead of Elem1 as the parent to create the Slot elements. Here is the fixed code:
void CreateXML()
 <Rack>          <-rootElem*
  <Chassis0>        <-Elem1*
   <Fuse1>0</Fuse1>
   <Fuse2>0</Fuse2>
   <Slot0>        <-Elem2*
    <Board1>0</Board1>
    <Board2>1</Board2>
   <Slot1>        <-Elem2*
    <Board1>0</Board1>
    <Board2>1</Board2>
  </Chassis0>
  <Chassis1>
   <Fuse1>0</Fuse1>
   <Fuse2>0</Fuse2>
   <Slot0>
    <Board0>1</Board0>
    <Board1>0</Board1>
    <Board2>1</Board2>
   <Slot1>
    <Board0>1</Board0>
    <Board1>0</Board1>
    <Board2>1</Board2>
  </Chassis1>
 </Rack>
 int a,b;
 FILE *fp1;
 FILE *fp2;
 CVIXMLStatus stat;
 CVIXMLDocument doc;
 //Build XML file
 //Get MF Header
 for (a=0;a<2;a++)
  Elem2 = 0;
  Elem2 = 0;
  if (fp1 != NULL)
    RemoveSurroundingWhiteSpace(rline);
    Elem2 = 0;
   fclose(fp1);
  for (b=0;b<2;b++)
   if (fp2 != NULL)
    stat=CVIXMLNewElement (Elem1, -1, line, &Elem3);
     Elem4 = 0;
    fclose(fp2);
    Elem3 = 0;
  Elem1 = 0;
 if (Elem1)
 if (Elem2)
 if (Elem3)
 if (Elem4)
 if (rootElem)
Message 7 of 9
(5,381 Views)
Mohan,
Thank you.
By luck, one of the lines in the first file did not throw an excemption, the one without the linefeed...
so I was looking at that as well.
Is there a document or link where one could learn the proper method of composing the XML file, in particular,
you disposed of the elements after each use. Would there be instances were you would not dispose of
them?
Thank you for a great solution!
-Chet:manvery-happy:
Message 8 of 9
(5,374 Views)
You should always dispose of the XML handles when your program does not need them any more - it is just like any other resource, for example, memory, file-handle, etc. A good resource that shows how to use the CVIXML functions is the samples/toolbox/xmlsample example program.
Message 9 of 9
(5,364 Views)
