LabWindows/CVI
add __MSC_VER macro
Matt,
Thanks for the response.  Per jr_2005's recommendations, I went ahead and created my own typedefs in a seperate .h file.
On a non CVI related subject, what Total Phase hardware are you using ?  Both the Beagle and the Host unit ?
I am currently written code for a test system which will use both of these units to test one of our products.
The only problem I am having is that I need to put the Host unit in Slave mode and also be able to send out commands in Master mode.  This has been an issue for me.
Thanks again
Diego
Message 11 of 11
(1,050 Views)
