debug64 doesn't like ATTR_ENABLE_POPUP_MENU
I discovered another issue when debugging 64 bit code.......
I am loading a panel with a table and set the ATTR_ENABLE_POPUP_MENU; this works as expected if the build configuration is set to debug 32 bit. Changing it to debug 64 results in a NON-FATAL RUN-TIME ERROR: Library function error (return value == -13 [0xfffffffffffffff3]). Invalid control ID
Interestingly, release64 configuration works withour error...
Needless to say - running CVI2013f1 Smiley Frustrated
(4,331 Views)
Before this post disappers... I could upload my project to the ftp server (so far I was unable to provide a small demo project) provided NI is interested in investigating it...
(4,275 Views)
Accepted by topic author Wolfgang
Hi Wolfgang,
Please upload your file to ftp://ftp.ni.com/incoming.  Please let me know what the name of the project is, and I will download it as soon as it has been uploaded.
Daniel
Daniel Dorroh
(4,243 Views)
Hi Daniel,
I've sent you a pm...
(4,238 Views)
It turned out that deleting the Debug64 folder resolved the issue. Thanks Daniel for the pm help!
(4,174 Views)
