LabWindows/CVI
dsc
Hi guys ...
When I try to install Labview DSC Module 2014 I get a message like this: "NI Labview 2014 must be installed before you can install NI Labview 2014 Dataloggin and Supervisory Module". But I've already installed Labview 2014 Smiley Frustrated  ....any solution for this?
Thank you.
(6,573 Views)
Accepted by eddcota
You posted to the wrong board.
Look at http://forums.ni.com/t5/LabVIEW/dsc/td-p/3022821
(6,558 Views)
What operating system you have installed? Your operating system is 32-bit or 64-bit? Did you install labview 32 or 64 bits?
David P.
Applications Engineer
www.ni.com/soporte
(6,535 Views)
I have Windows 8.1 64 bits and installed Labview 2014 64 bits
(6,529 Views)
Accepted by eddcota
NI LabVIEW Datalogging and Supervisory Control Module it's not compatible with Windows 8 64-bit using 64-bit Software, but it is compatible with Windows 8 64-bit using 32-bit Software.
National Instruments Product Compatibility for Microsoft Windows 8:
https://www.ni.com/en/shop/software-portfolio/national-instruments-product-compatibility-for-microso...
Best regards.
David P.
www.ni.com/soporte
(6,512 Views)
