escape codes ANSI works but also types it
my code is like this (shortened):
#include <cvirte.h>
#include <userint.h>
#include "word97.h"
#include <formatio.h>
#include "toolbox.h"
#include <utility.h>
#include <Data Types.h>
#include "Function Prototypes.h"
#include "Globals.h"
#include  GUI_HEADER
#include <stdio.h
some code above ( not relevant)
ErrChk (Word_SelectionTypeText (currSelHandle, NULL, "<Esc>[7A] ...some text.."));
some code bellow (not relevant)
and it works (move 7 spaces up) but then it also types <Esc>[7A] which i dont want it to, i just want it to move 7 cursor lines up and then not type my code. i have tried it above (bellow this text) but then it comes up with 10 errors and really doesnt like it. im wondering if there is a thing like cout or echo for cvi. another problem is that im using a very old version of cvi, cvi6.0. Plus if there is any other way to move it up 7 lines then im willing to hear it , or to delete 7 line (but i doubt you can delete it as no-one has any idea how)
<Esc>[7A]
ErrChk (Word_SelectionTypeText (currSelHandle, NULL, "...some text.."));
thanks for any help, it could be pretty easy i dont know as im new to CVI, but i have done programming here and there on assembler and C++.
lewis
(4,402 Views)
Hi Lewis,
Welcome to the NI discussion forums.
It's difficult to analyse this code because I don't have access to the particular functions or header files you are trying to call. Is there a way you can provide me with the full project so that I can see what you are trying to do?
For now I have assumed that the escape charactor you're trying to send is 7A in hex, have you tried replacing <ESC>[7A] with \x7a ?
Ben Clark
(3,649 Views)
its very long (like 1200 lines is the biggest file and there are 12 files all different sizes if you want them all) as its a front end sytem with lots of different calculations and things in. My friend said "seeing as your doing a hnc in electronics program try to figue this out" and well i have got rid of about 10/11 other errors but this one is abit more confusing as the obvious doesnt work and nether does the difficuilt, but basically it imports a word document onto a new one , imports a table and then adds more lines unerneth it.
The problem occurs that it is too long by a line but there are 7 spaces that i can get rid of this is because the table is 8 colloms wide and doesnt stop when it ends it goes on another 8 times (thinking there are more rows when there arnt). This is why im trying to delete some lines or go up a few lines
also the hex code didnt work it just imputed a ":" and that was it, it didnt go up any lines. Is there a code like "cout ("\b")" or something like that for cvi?
Finally the headers dont really do anything except define things and input different calculations / set up that dont relate to this little bit of code
thanks for looking into this,
lewis
(3,640 Views)
Apologies, I only really needed the code to understand the function and to test any of my suggestions. It's very strange that the function performs the escape sequence action (<ESC> is the escape sequence character) and then prints it out as text as well. I previously hadn't acknowledged that the [7A instruction was to place the cursor upwards. What happens if you do not include the extra "]".
You're writing in the C language, so \b should be a non-destructive backspace character inside a string.
Ben Clark
(3,603 Views)
the strange thing is that the \b doesnt work at all it just prints an unknown symbol (looks like a card with a dimond in the middle) but then /n and /t work as i have tried them allready.
and i know esc is an escape sequance character that why i didnt understand why it printer it ether, but i tried it with out the bracket and it still prints "<ESC>[7A ..... somewords..." so that doesnt work ether sorry. is there a different way you know that will work with cvi 6 that deletes 4/5/6/7 lines or moves up 4/5/6/7 lines? it could be a string or anything (im willing to try alot to make it work)
any solutions will be greatfull, and thanks ben for trying to sort this out for me,
lewis
(3,589 Views)
Hi Lewis,
It seems that I don't have access to the word97 header so I apologise if this seems very hit and miss.
I've read up on it and there also seems to be a function that allows you to move up the selection, try playing around with the Word_SelectionMoveUP function. Prototyped as
HRESULT CVIFUNC Word_SelectionMoveUp (CAObjHandle objectHandle,
                                      ERRORINFO *errorInfo, VARIANT unit,
                                      VARIANT count, VARIANT extend,
                                      long *returnValue);
 For example putting the following above your Word_SelectionTypeText() function and removing the escape sequence might work:
ErrChk(Word_SelectionMoveUp (curSelHandle, NULL, CA_DEFAULT_VAL, CA_VariantLong(7), CA_DEFAULT_VAL, NULL)); /*Defaults to "line" units, and "extend mode" to "move"*/
If you're still having no luck then it may be better if you sent me everything, so that I can have a good idea about what else is going on in the code and I can try a few things for myself.
Ben Clark
(3,575 Views)
